TwinTurbo.NET: Nissan 300ZX forum - Re: A/c drier sensor location?
Subject Re: A/c drier sensor location?
Posted by parrotheadz on May 15, 2013 at 7:14 AM
  This message has been viewed 208 times.
In Reply To A/c drier sensor location? posted by Jkova300z on May 14, 2013 at 06:09 AM
Message looking at the front of the car the dryer is located on the left front through the bottom air inlet. also easy to access if you remove the center nose piece where the air box is . the only sensor on the dryer is the low pressure switch. hope this helps. Cheers.
